Lubricant
Simba
Specialized Allez 24 Rider
Can anyone recommend a good lub for chains, cranks etc that is easy to apply and does the job properly. I currently use the one from Halfords, the lub itself is good but I have to pour it into a cup and apply by a small brush.
buddha
Finish Line Wet for rain. I got the 3 bottle bundle almost 3 years ago and still haven't run out!
For dry weather on my bestest road bike I've settled for Prolink Gold. Still on the same bottle after almost a year.
tyred
Ireland
Engine oil. Cheaply and easily available. You can apply to each link of the chain using a flat screwdriver dipped in oil as a "dropper."
PpPete
Chandler's Ford
I used to use Finish Line Wet.
Then the price shot up from 4.99 to 7.99 around the time I was thinking of new bottle. So I tried Halfords own dry lube which was cr@p.
Now on ProLink Gold. Very smooth & quiet drive chain. Seems to pick up less gunge that the Finish Line Wet. The pen applicator is an excellent idea, as you can get precisely one drop on each link.
giant man
Essex innit?
Glad to see a lube thread without the usual WD40/GT85 debacle!
The recommendations of Finish Line cross country and ProLink Gold are exactly what I would recommend .....
Cubist
Still wavin'
Ovver 'thill
That's because the OP asked about chain lubes, and neither of those are suitable, and only one of them's a lube. :smile:
l4dva
Sunny Brum!
This may be a daft question but dose that lube pen come already filled with some lube in it?
Do you use it anywhere else other than the chain as well??
