magura marta rear caliper on front
02GF74
anyone used a magura marta rear brake caliper - IS mount - on the front?
the front and rear caliper differ by one of the lugs being longer (same as on Shimano IS mount calipers) so when the rear one is fitted to the front, it is a bit further away - maybe 10 - 15 mm.
So since the stanadard 160 mm is is too small, will a 180 mm disc work with this set up?
