Fastpedaller
- Norfolk
Being new doesn't make a failure any less painful.
But it does make it more unexpected.
Difficult to see clearly in the vid clip, but that appears to be the handlebars that separate from the steerer. Totally different to a fork failure.Happened to George Hincapie a few years ago. Apparently it was an aluminium steerer bonded to a CF fork so the join was the weak point.
There tend to be two kinds of failure mode in normal machinery. Either early on, sort of teething trouble, or later on after long service when wear/fatigue sets in. Failure rates would typically form an inverse bell curve (or bathtub curve) so a failure on a new bike would not be atypical.It was a new bike.
I've had two bike frames fail, neither were carbon and both were bought new. Fortunately no injuries.
Good luck to this bloke, but how will PXs never ending bankruptcy affect his case?
Should be down to PXs liability cover?
I'd have thought so, but if they haven't paid for it, is it still there?
The liability will be provided by whomever had the cover in place at the time, regardless of what's happened since.
It seems most brands have had carbon fork recalls but from what I remember reading the carbon fibre blades bonded to a aluminium steerer was a much more common failure than the full carbon fibre forks maybe 70% to 30% as an impression but the bonded forks often took time for the bonding to break down. Of course carbon fibre forks are hand made, layered etc so its something which can be great 98% of the time but then 2% fail which is enough to merit a recall. As a heavy chap I don't even consider carbon fibre but because of how forks fail and collapse the structure of the bike they are a lot more dangerous than carbon fibre frames. Personally I'm a huge fan of steel forks which have incredibly low failure rates and not bike weight obsessed so for peace of mind go steel.
There's a long history of lightweight performance bicycle forks causing injury and even death in fact there was a British manufacturer Viscount that used aluminium forks that were called death forks years ago with a steel frame.
The benefit of steel forks isn't just their strength and durability but they give good notice of when they are going to fail and if you get the fork design which has tapered tubes with a slight curve they offer good a level of flexing for comfort. Some modern steel forks are straight blade and don't really flex. They might be a bit lighter though.
Carbon fibre often has the cheapest nastiest manufacturing as its so labour intensive. Quest Composites who manufacture for Trek and Canyon and likely many other brands too have horrible cramped conditions and you can see clearly in this factory image from Quest themselves that the woman in the foreground is not wearing that protective hat properly and any dust or dirt that gets into the carbon fibres is like a cutting blade as the forks flex.
completely irrelevant. They have public and product liability insurance, the claim being handled by the insurers, whose first course of action is always to deny liability, which they have done. it will either come to court in the fullness of time or more likely be settled before then.
It will be settled well before the court case.
