- Essex
Think i'll get my anorak out
Good theory but a smaller wheel size will give even higher readings due to more rotations for a given distance, if you swap the 40.00 and the 40.18 around it might work better.No need to mess about with percentages or witchcraft, it is really simple.
IF you are confident/happy that the Garmin/RWGPS figure of 40km is the 'true' figure then adjust your wheel size setting as follows
New wheel size = 2023x40.00/40.18
I saw a science program on TV some years ago where they asked the question "how long is a piece of string?" They had a piece of string and investigated all the practical and conceptual problems around making a statement about how long it was. (I think they may have mentioned the coastline problem there)
Answer on that part is "25% of its origional length"
I could explain how wrong you are but I am going to bed after a night shift so it will have to wait. See if you can work it out for yourself in the meantime.....Good theory but a smaller wheel size will give even higher readings due to more rotations for a given distance, if you swap the 40.00 and the 40.18 around it might work better.
Well if one assumes that the variation in direction of the front wheel AVERAGES (mean) at 2% the difference in measurements (between front and rear wheels/rider) would be 0.06% (ie negligible).the front wheel continually does the little balancing adjustments, meaning it travels further than the bike itself. It simply goes in less of a straight line.
Well if one assumes that the climb/descent on a ride AVERAGES (mean) 2% (a @Sea of vapours hilly ride) the difference in distance (between a completely flat ride and the one with climb and descent in) would be 0.06% (ie negligible). "basic trigonometry innit" [cos 2 degrees]deal with that massive issue of the fact that GPS measures linear distance (I think), whereas a Cateye will measure actual distance your tyres have travelled. All those ups and downs....basic trigonometry innit
...... the difference in distance (between a completely flat ride and the one with climb and descent in) would be 0.06% (ie negligible). "basic trigonometry innit" [cos 2 degrees]
Would you be going further at the start(cold tyres) than at the end(warm tyres)?You'll need to consider the expansion of air in the inner tubes as temperature and barometric pressure vary. Just apply the Ideal Gas Law
PV=nRT
NB Thread title has 'maths' in it.
Well if one assumes that the climb/decent on a ride AVERAGES (mean) 2% (a @Sea of vapours hilly ride) the difference in distance (between a completely flat ride and the one with climb and descent in) would be 0.06% (ie negligible). "basic trigonometry innit" [cos 2 degrees]
