Max power - light bulb
albion
Gateshead
Assuming the wiki is correct the 23W outputs about 2 watts of light whilst the 60w outputs about 1 watt of light.
I can safely assume that the remainder is to be measured in willy waves.
albion
Gateshead
Oh. the reason has to be that 23w is usually the maximum you can buy.
Likely when a 30w CFL comes out it also works but as it is has not been tested yet it is obviously just not 'supported'.
Profpointy
That is very plausible - I think you may have got it.
Profpointy
[QUOTE 3049127, member: 9609"]well I have a 25w one, so I am going to get my affairs in order, then plug it in and see what happens - should I wear my helmet ?[/QUOTE]
best put the lamp into a bucket of water before turning it - just to be on the safe side
Yellow Fang
Reading
Perhaps you should wear your shades.
Anyway, haven't CFLs been overtaken by LEDs?
raleighnut
Could it be due to the heat from the "transformer" (called a gear tray on normal fluro's) the tube doesn't get that hot but the electronic gubbins do, I've manufactured more than a few shop displays and "light boxes" and the need to dissipate heat is something "designers" never factor in when dreaming up that fabulous boutique interior,
