mrandmrspoves
Middle aged bald git.
- Narfuk
I am also a little obsessions about these things and would find it distracting to have the brake unequally adjusted - even if functionally perfect. The issue with V brakes is that when very finely adjusted, the weight and pull of the brake cable affects the balance as soon as the brake is applied and pulls it back out of balance. You can sometimes partially solve this by how the cable is routed but the only effective solution I have found is to increase the tension on the springs so that they are able to exert enough pull to overcome the cable tug. This does mean that they require slightly more pressure on the brake lever but not enough to be particularly noticeable. To make this adjustment both adjustment screws need to be turned clockwise a few turns and then fine adjust by backing off (turn anti -clockwise) whichever side is nearest to the rim. It is worth applying and releasing the brake 2 - 3 times regularly while making the adjustments.
