While steering with there........When we were in Tenerife the tandem mobility scooters were everywhere. Near all the riders were Brits, often with a fag in one hand and a beer in the other.
No requirement for a number plate as far as I know. Class III (that's those that can do 8mph etc) must be registered with the DVLA but I didn't think you get a number plate in exchange.Difference in cultural norms, maybe? I have noticed that pavements in France aren’t always suitable for mobility scooters - too narrow, under repaired or lack of drop kerbs.
Only those with a proper number plate should be on the road.
If the batteries are past it you will need traction batteries, not a car starter, or caravan leisure battery, they aren't cheap, also you will need to test the batteries under load to check the voltage drop & recovery.Just picked this bad boy up and its a beast ! I'm just charging the batteries now and will see how well they last when i test ride them flat .... I could use a multimeter but wheres the fun in that
I thought it was a littleun
Thanks . I took it for a blast this morning in the rain . I thought that would be a good test to see if everything was ok ( i didn't expect it to belt down like it did though ) Four miles done at full speed 4mph and the battery is still showing a near full charge on the scooters screen .If the batteries are past it you will need traction batteries, not a car starter, or caravan leisure battery, they aren't cheap, also you will need to test the batteries under load to check the voltage drop & recovery.
It's more effective than the hornLethal machine, is that flame thrower legal down your way.
Scooter delivered and she crashed it into a bus shelter .
She said she hit a bus stop but i explained that to hit the bus stop she would have to aim at a small post at the side of the road . She had hit the building next to the bus stop . Nice to see her laughing her head off again
