brokenbetty
- London
I'm converting an old 5-speed bike to use a Nexus Inter-8 hub gear.
The original gear cable ran from a downtube shifter, through a cable guide on top of the bottom bracket to a cable stop about 10cm from the end of the chain stay, then to the mech. Between the stop and the mech was a short length of outer and the rest of the run was uncovered (ie pretty standard rear cable routing).
The hub gear shifter is a grift shift and intended to use a full cable outer. The outer starts where the cable exists the shifter and finishes at a stop on the hub joint.
I could use a full outer with cable clips and ignore the existing routing, but I think it would be neater to use it if I can.
The existing braze-ons are:
Are there any problems with doing this? Also, is anyone aware of a band on cable stop for downtubes? I've found this: http://www.sjscycles...-Stop-18209.htm - will it do the job?
Thanks
Liz
- a small nub on the downtube where the band on shifter was
- a cable guide on top of the bottom bracket
- the cable stop on the chainstay
Thanks
Liz
