MTB sizes
stalagmike
Enormous member
Milton Keynes
I'm 6ft 3 with a 34 inch inside leg. Would a 19in frame 90s MTB fit me?
I know a test ride would be best way to find out but just in theory...?
Spiderweb
Not So Special One
North Yorkshire
I think it’ll be too small.
Drago
You may just be able to ride it comfortably, but it'll be the absolute lower limit. I'm fractional,y taller than you and manage on my 19" Alpinestars, bu 2mm smaller and it wouldn't work. It's right on the edge.
rogerzilla
MTB sizes are often a tradeoff between needing an absurdly short stem or needing an absurdly long seatpost. There's a trend to very steeply-sloping and very long top tubes, which can make it hard to get a good fit unless you have your saddle fairly low for your height. In contrast, I've never had a problem finding a road bike that fits.
stalagmike
stalagmike
Enormous member
Milton Keynes
What would be the minimum size would you say, for gentlemen of our kind of proportions?
KneesUp
I ride a 1989 MTB with 175mm cranks. It's 20" and I have the (original) seat post pretty much on it's limit, and I'm only 5'11" (32" inside leg).
SkipdiverJohn
Deplorable Brexiteer
London
I would pay more attention to the Top Tube length than anything, as a short one makes for a cramped ride and a really long one may be too stretchy. Someone 6 ft 3in with a 34" leg I reckon would want an old-school 23" field gate style MTB for general utility/ leisure riding, or maybe a 21" of they want a bit more standover clearance to protect one's delicate bits if riding on rough stuff!
Here's two Raleighs, both 1991 bikes with 501 frames. the black one is 23" the multicolour one is 21", both have the same reach, frame geometry, same head tube height. At just under 6ft with a 33 1/2" leg, I can ride both fine, but the black one has to be treated with more respect:-
stalagmike
stalagmike
Enormous member
Milton Keynes
View attachment 456607 View attachment 456608
Thanks for that. Has cleared up a lot of the mystery for me. I guess with later bikes with sloping top tubes I would need to be going for the biggest possible.
