muck off
Discussion in 'General Cycling Discussions' started by wisdom, 14 Jul 2012.
  1. wisdom
    wisdom Veteran
    Blackpool
    Well its finally stopped raining Could be tempting fate there!!!!!!!!!!!!!!!!!!!
    I allways clean and lube the chain using the mickle method but the question is is the "muck off" spray good to use on everything else its a road bike and is covered in greasy crud from near two weeks of commuting mostly in the rain.
    Question 2 is what are the best quick links to carry?
  2. TonyEnjoyD
    TonyEnjoyD Veteran
    Question 1 - yes
    Question 2 - the one best suited to your chain type - as the LBS
    Dismiss Notice
