Mudguards for Genesis CDF
Rustybucket
Rustybucket
South Coast
They arent the easiest things to fit - Im half way thru getting the front ones on - They are rubbing so need to hacksaw the stays abit shorter on one side! Hopefully have them sorted soon! Im thinking should of just bent them rather than following the instructions and shortening the stays!!!
Rohloff_Brompton_Rider
Formerly just_fixed
Once you've done you won't regret it, they look much much tidier.
Rustybucket
Rustybucket
South Coast
I hope so - spent half the afternoon in the garage yesterday - And havent even finished the front one yet - The spacer was a good call so the stays dont have to bend - however it does stick out a long way - will post pics once I have got fitted ( If I ever finish....)
Formerly just_fixed
If you feel it sticks out too far you could always trim it down until your happy.
Rustybucket
Rustybucket
South Coast
well I cut down the front stays too long & now they rub & wont fit - Ive ordered some more spares hopefully wont bugger it up next time - I wont be beaten by a set of mudguards!!!
Formerly just_fixed
Oh dear, I use a pair of pliers to cut the stays but I've got gorilla hands. Gutter - I hope you have better luck next time.
LBS for mudguards every time, well worth any fitting fee that may be charged IMO, let them make a boo-boo of it!
Rustybucket
Rustybucket
South Coast
Well I got mudguards fitted for my Boardman Hybrid today - gave in and got my LBS to do it - looks like they did a really good job
going to give in and get them to do my CDF tomorrow
Dan B
Disengaged member
My tip for mudguard stays is to file them halfway through and then snap them off. Hacksaw blade just seems to skitter all over the stay, filing was so much quicker.
Having said that, I put Raceblade XLs on my (2013) croix de fer so that I can remove them without needing tools/losing bits, if I want to take it somewhere proper muddy. 32mm tyres, the clearance is just about adequate.
Rustybucket
Rustybucket
South Coast
Nearly a year later - I finally have them on both bikes - Just got my cdf back from the LBS - actually doesnt look too bad.
Vickster you were right should of just got them to do it in the first place!
