Hi
I wonder if anyone can help.
We have lived in this house for the last 21 years and have never had a problem with banging water pipes until a few months ago!
About 8 or 10 years ago we had a water meter fitted, the type that replaces the innards of the stop cock on the footpath. again no problems with baning pipes.
sometime last year when it was really quiet at night we could hear a noise which sounded like running water and after this went on for some time I eventually traced it to a leak on the water meter. I called Yorkshire Water who came and replaced the water meter with a different type.
It was at some point after the replacement of the water meter that we started to notice banging after we had used the cold water. This isn't 'water hammer' as I understand it when you close the tap you get a bang in the pipes!
What we get is: After we run some cold water and then shut it off about 3 to 6 seconds after the tap is closed we hear a slight knocking noise then 3 to 6 seconds later another one and this goes on for variable lengths of time until it finally stops.
After searching on the internet I have shut off the water at the internal stop cock and opened all the cold water taps, flushed the toilets and run some hot water in order that the ball cock in the header tank opens. once the water stopped running I turned on the water at the stop cock and starting at the lowest tap closed each one when water was flowing without spluttering.
This appeared to solve the problem but after about two days the problem was back so I went through the same procedure with the addition of leaving the taps open to drain for a longer period of time until there where no drips. This again seemed to work but after about a week we are back again to the banging!
Any help you could give to solve this problem would be greatly appreciated as it's starting to drive me mad!
Thank you in advance for any help.
