My first (of many) stupid questions - Things are rather quiet.
marko
Lincolnshire
I knew it would not be long before I was asking my first stupid question so here goes.
I have had my bike almost a month now and have been out on almost every single night.
Now when I am riding along, when you stop peddling and are coasting you get the ticking sound from the back wheel (a ratchet sort of sound). This is the same sound as you get when you peddle backwards etc.
I hope somebody understands what I am trying to describe here.
I have heard this sound on every single bike I have ever come across.
Well tonight, that sound is gone!
When I am riding along and then stop peddling and start to coast, silence.
When I peddle backwards, silence
The bike seems to be riding OK, gears change, peddles go round, bike moves forward etc but all in a very quiet fashion.
So is this normal or is there something I should be looking at here?
Thanks
OLDSHUNTER
glesga
HAVE YOU OILED IT
Radius
SHREDDER
London
The sound you're hearing is the ratchet mechanism in the freewheel, and it could now be a bust freewheel, the mechanism could have gone. Not normally a good sign.
Your clicking noise wasn't attached securely and has fallen off!
Actually I don't know. If it had one to begin with and now doesn't, but the bike still works I wouldn't worry. Is it a new bike?
M
marko
Lincolnshire
OLDSHUNTER said:
HAVE YOU OILED IT
YES!
:birthday:
Yes. It's a 4 week old Trek 7300. I just wanted to check if this was a real problem before I got on the phone to the shop
numbnuts said:
have you gone deaf :birthday:
Pardon
simon_brooke
Auchencairn
Is the right answer. The OP says the transmission is still working so the ratchet has not jammed entirely. However what tends to happen is that the grease gets more viscous with age until it's acting more like glue; at that point the clicky sound diminishes and shortly thereafter the ratchet stops working all together.
Disassemble, clean out the old grease; regrease with fresh grease, reassemble.
It'll be fine.
M
marko
Lincolnshire
At 4 weeks old on a £500 bike, I think this will be a job that the bike shop will be doing :birthday:
Thanks
Radius
SHREDDER
London
Unfortunately most bikes aren't adequately greased by their supplier / shop, only furnished with a thin layer to make everything run smoothly for a short while. It's not uncommon to receive under-greased bikes from a shop, but you're right, they should sort it out. Where did you buy it from?
M
marko
Lincolnshire
Thanks
I bought it from an independant this side of Peterborough.
Their advice (over the phone) is that if it is not slipping at all (and it isn't) then don't worry about it right now. As it is due in for it's 6 week initial check in a couple of weeks however, they will double check all is well then, however it could be just "one of those things"
So I shall see how things go for the moment but as the bike seems to be riding just fine (just a bit on the quiet side) don't worry.
In the meantime, whilst I am out tonight I will keep mickles advice in mind just in case the noise has fallen off and I spot it in the gutter :ohmy:
swee'pea99
Some click, some don't. I had one that didn't and I rode it for a couple of years and thousands of miles with no probs.
Kestevan
Last of the Summer Winos
Holmfirth.
Then again, my Fulcrum did initially click. Then the pawl spring snapped and it went all silent, but continued to run OK.
I ignored it for a couple of weeks - right up until the bearings disintegrated.......
M
marko
Lincolnshire
My worry was that it did then it didn't hence the thinking that something has changed/broken.
I have spoken to the shop, I have asked advice here and it is due a 6 week check in 2 weeks time.
If it fails before then (it might or it might not) then it will get taken back to the shop for them to sort it. If it carries on for another thousand miles then fair enough.
