A long time i set out on here to list out how i was going to build up a set of lights. I never really kept up with the posts and my design changed somewhat since then, so i figured i would complete my task and share the ideas with others.
I took them out on their first full nighttime ride the other day and quite simply, they are fantastic. The fronts are so bright that car drivers flashed me to dip them ... i just pointed them at the ground a bit more. In a couple of cases, some drivers dipped their beam before coming round the corner ! Now thats what i'm talking about
In another forum, i posted this picture of the throw from my twin 3W Lux red light unit ... remember, this is the REAR light ...
Some people were asking questions about it, so i thought i would share the deets ....
Seriously folks, its blindingly / dazzlingly bright and i think too powerful for using on the roads in all but the absolute worst of weather. I have 2 units of a similar design on the front of the bike which are Seoul P4's and oncoming drivers flash their headlights at me to point them downwards.
I will finish the rear light build though and get it seat / seatpost mounted, just for the sake of completing the build and novelty factor.
As for its components, actually its quite a simple build compared to some excellent detailed work that i have seen posted here in terms of workmanship. Having wasted time and money trying to build something fancy using dimmer controlled boards, i wanted something simple that would switch on and off and thats it. So I spent a LOT of time looking round for the right bits so that the build would be simple and this is result of the internals :
Case:
An extruded aluminium case which has an internal dimension of about 20mm x 42mm ... perfect for two 20mm LED's + lenses.
Source: Maplin
Box type: 1455C801
Current Driver:
An all in one driver with integral heatsink. Big bonus was that it has screw in connectors for less hassle of me making an arse of soldering tiny joints. Also 20mm in height ... a perfect fit for inside the box !
Source:
LED-Tech.de
See similar products for different versions of the this ( 1A, 700mA, 350mA )
LED
i think they came from dotlight.de. But basically, any luxeon start emitter should do the job. Remember, this design will work for front and rear lights
Optics + Holders
Carclo optics and holders ... 20mm in diameter ( oh look, that magic size again ! )
The rears were elliptical lenses.
The fronts were a narrow beam + wider beam in each unit. Great for a good spread of light.
For the rear lenses, to get the lens stripes vertical, i had to file out an extra notch in the holder so the lens would sit in the right direction. ( Its only plastic )
What you dont see above, but is fitted on the final units is a small thin sheet of plastic which covers the front of the lights to protect them from the rain and muck.
LED heatsink / mount
Ah, my master stroke
In BnQ, there is normally a small section where you can buy lengths of steel and aluminium in all shapes and profiles. One of these is an alu C-section shape which is ... you guessed it ... 20mm tall. Cut to the right length and filed down to allow it to fit into the box at the edges and its a perfect sized heatsink/mount combo.
Bar Mount
I used a lumicycle bar mount ( you can buy them as spares online ). If you slot the driver in upside down, then the middle space between the heatsink sides leaves enough space to put a small nut to tighten the lumicycle bolt onto. Simple.
Power source
7.2V RC batteries NiMH. ( these read 8.4V when fully charged )
But basically, if you read the specs on the driver board, then it can handle a max supply voltage of the 2 leds ( 6.5V ) PLUS an additional 4 to 5V on top of that ... so that gives me and input of around about 7 to 11V .... the RC batteries sit perfectly in that range and are easy to source and connect together using tamiya connectors.
Throw it all together and its a perfect little fit with super heatsinking quality and minimal fuss about making it.
so there you go.
What about the price ? I hear you ask. Well, cause i bought the bits of a long long time and wasted money on previous driver boards, i dont have an exact figure. But i reckon that its in the region of about £45 to £50 per light unit, not including the power source.
cheers,
Don Fisha
Case:
Source: Maplin
Box type: 1455C801
Current Driver:
Source:
LED-Tech.de
LED
Optics + Holders
Bar Mount
Power source
so there you go.
cheers,
Don Fisha
