oxford_guy
- Oxford, England
Shiny. shiny (that won't last long...)
tdr1nka said:Oooh, that's pretty!![]()
WindyRob said:oh very nice, now if that had been a thorn there would have been at least 100 posts by now pointing out that there are too many spacers
Windy
WindyRob said:So where you going to go to first then, a bike like that needs to go touring...
yello said:Very nice indeed. A Schmidt hub? San Marco Rolls saddle?
Its a very tight fit to get it under the brake cantilever, there isn't much scope for moving it higher, though I have since pointed it up a little bit, which seems to have improved things a bit. I guess the only other option would be to get a different bracket - anyone know somewhere which sells these things?If you don't mind me saying, and you may have already noticed, I think the Cyo could do with mounting a bit higher, you should be able to slacken off a couple of bolts and swing it around.
oxford_guy said:Its a very tight fit to get it under the brake cantilever, there isn't much scope for moving it higher, though I have since pointed it up a little bit, which seems to have improved things a bit. I guess the only other option would be to get a different bracket - anyone know somewhere which sells these things?
yello said:Will the bracket mount upside down? That'd give you a few extra cm by the looks of it. Or even bend a little? Failing that, SJS Cycles may be able to help.
JonoB said:You have just caused me to check out the Hewitt website. Wish I hadn't now because a can see a visit across the border looming. Did you spend the extra to be measured on his "special machine thingy"?
