My riding has got worse
Discussion in 'CycleChat Cafe' started by walker, 22 May 2008.
  1. walker
    walker New Member
    Bromley, Kent
    It's been a while since I was last on a set of rollers till I just bought myself some recently, I remember it being hard to judge but I forgot just how hard. got on them last night and was all over the place, I never knew my handling skills were just so bad.
  2. John Ponting
    John Ponting Über Member
    Herts
    could partly explain the popularity of turbo trainers. I'm sure there are other, more valid reasons, for turbo -v- roller.
  3. MichaelM
    MichaelM Veteran
    Tayside
    As an experiment (if possible), try using a heavier set of wheels, heavier rims/tyres especially may (should?) be more stable.
  4. OP
    walker
    walker New Member
    Bromley, Kent
    like the idea but I doubt very much it will work, I would of still gone all over the place had I fitted car tyres to the bike.
    I was ok after 10 minutes, but I could'nt believe my handling could deteriorate so rapidly like that.
  5. MichaelM
    MichaelM Veteran
    Tayside
    I'd like to give it a try myself. I've read quite often that there's a noticeable difference between heavy/light tyres/wheels. It would be fun to calculate the figs, then try it to see.
  6. yenrod
    yenrod Guest
    I thought Rollers are a whole lot worse to ride than the actual road itself :eek:
  7. graham56
    graham56 Guru
    First and last time i was on rollers was back in 72, they belonged to a mate and i almost crippled myself when i fell off them.:eek:
    Not as easy as it looks.
  8. OP
    walker
    walker New Member
    Bromley, Kent
    only as you have about a foot and a hlaf to move about in, about the same as a cycle lane
  9. Trillian
    Trillian New Member
    good practice then!
  10. yenrod
    yenrod Guest
    Merckx was a big fan of them !
  11. OP
    walker
    walker New Member
    Bromley, Kent
    and look how crap he was:biggrin:
  12. MichaelM
    MichaelM Veteran
    Tayside
    Some e-motion rolloers in action here
  13. Keith Oates
    Keith Oates Janner
    Penarth, Wales
    When I was in Yangzhou this winter and the snow and ice was bad, one of the lads in the LBS told me I could have his a try out. Reading the above means one of two things, either he couldn't use them or he wanted me to have some problems, glad I declined the offer!!!!!!!!!!!!!!!
    Dismiss Notice
