Milzy
New KTM chain fitted & oiled. Was made to the same length as the old one.
The problem is when you put plenty of torque down on the peds it will sometimes slip a little. I know the chain is not worn in to the sprocket teeth, I've checked for stiff links but can't find any. Will this stop happening once it's bedded in? The sprocket teeth have a little bit of ware, It's only done a few thousand miles in a year at the most.
