new saddle on my tt bike
steve1959
My saddle on my time trail bike gives me a lot of pain when i do 25m or 50mcan some help.
I think that it is set up ok its just painfull on the long rides.
I can do a 10m ok 25.7 is my PB and i have no pain.
Will1985
South Norfolk
How low are you on the front end? Perhaps for the longer events you should consider sacrificing a little aerodynamics for comfort by raising your handlebars and armrests?
I ride anything up to 25 miles in the same position, but raise the bars about an inch for anything longer. It doesn't help the saddle area so much as my back and neck.
If you are riding the same setup, are we to assume that the pain kicks in after 15-20 miles? One solution might just be to ride in that position more and you'll get used to it. Generally with a position as extreme as a TT, you know if the saddle position isn't right within a couple of miles - ideally you do not want this to change much between bikes.
Maybe a picture will help?
