MontyVeda
- Lancaster... the little city.
cheers... just re watched the video and realised that it is indeed a different model featured.You change the drive on the model in the picture by moving the belt between grooves in the pulley in the top left corner. No need to lift the plate.
this snippet from one of the reviews is a bit concerning though...
" The main issues are with very light overall weight, which means the unit slides around too easily especially when opening the lid, and imbalance caused by the unit only having three feet, just one at the rear, which makes it unstable. The unit really needs rubber pads on the feet. An initial problem was an appalling motor resonance which I found was caused by the lid resting on the base. I cured this by cutting out tiny squares from a rubber band and sticking them to the lid, which while not eliminating motor noise completely has reduced it to acceptable levels for a budget deck "
I don't tend to listen to music very loud so if the motor's a bit on the noisy side, it's going to be annoying... any comments?
**edit** or is it just a simple case of not closing the lid when in use???
oh and the other thing... replacing the belt... is it a specific belt to the model? if so, are they easy to come by and inexpensive?
So here's hoping they go back down in price.
