RyanMcGrath
Changed my standard wheels to some cosmic carbone sls and love them but since changing them I've had a new cassette fitted I'm getting a weird noise from the rear and don't no what it could be!! Any ideas
Cheers
Cheers
When i changed wheels recently it made weird rumbling noises, turned out it needed a small spacer just as you describe , even though the lock ring was tight there was enough play in the cassette to cause poor shifting and a noise.Did you check/adjust your rear derailleur when you had the new cassette fitted ? (might be cable tension/indexing out if it's in all gears) or perhaps the new cassette needs a shim/spacer (give it a wiggle - it should hardly move at all).
Did you change the chain at the same time? (might need a new chain - unless the old cassette/chain had very little use)
