https://newatlas.com/steering-assist-ebike/59373/I'm holding out for power-assisted steering.
Would that be those that have bought Di2?Might appeal to geeks n all...
Read the commentsHow will it send a signal from the lever to brake if the batteries are flat?
This looks like the basis for a power-brake - like in motor vehicles, where the brake would not fail (entirely) even if the servo fails. The actuator(?), item 40i, would just need to be installed in a floating way, so that it could be pushed to the left by the break lever, to provide a fail-save, non-power backup.
Drago, earlier:Soon we'll have bike riding robots to save us the tiresome bother of riding bicycles ourselves.
Not a good idea if the brakes are less effective than you are used to. Rather like when you see an e-bike rider with a flat battery.I doubt once your AAA battery is flat the brakes stop working, just like a servo in a car, if that stops the brakes still sort of work
Never seen that as far as I know, mine rides perfectly fine if the battery is switched offNot a good idea if the brakes are less effective than you are used to. Rather like when you see an e-bike rider with a flat battery.
Read the comments
Di2 is superb.Would that be those that have bought Di2?
maybe if they chuck enough spaghetti at the wall, something will eventually stick.
