Vapin' Joe
Formerly known as Smokin Joe
- Bare headed cyclist, Smoker
All the same whether they're cheap or expensive?
Decent speaker cable need not be expensive, I use 4x5m lengths of QED 96 strand (bi-amped set up).....................total cost £20 but every year I cut off the bared section and strip 1/2" of outer and reconnect.Taking of spending tons of money on cables, I read a really interesting article about this the other week, one of the subjects was speaker cable, this guy was saying you can buy expensive cable if you want but unless you've got a >£10k system you won't get any benefit and it will be barely noticeable anyway. Also interesting was matching lengths of cable, he said if it's over 500' you might get a tail-off in quality otherwise no difference. Smoke and mirrors.
Why?Decent speaker cable need not be expensive, I use 4x5m lengths of QED 96 strand (bi-amped set up).....................total cost £20 but every year I cut off the bared section and strip 1/2" of outer and reconnect.
Why? (Genuinely courious ). Sorry for the repeat why, must have longer cables than TimDecent speaker cable need not be expensive, I use 4x5m lengths of QED 96 strand (bi-amped set up).....................total cost £20 but every year I cut off the bared section and strip 1/2" of outer and reconnect.
Nobody is disputing that. I even said it upthread. Analogue was susceptible to interference. Quality of connections mattered. Better quality equaled better sound. However that's not the case with digital. There's no loss. It's either perfect (as the original at least) or it cuts out. There's do degrading.cables (not digital) do make a difference and I can vouch for that (I have pretty decent (older) hifi
listen to a track using copper cables a few times, then switch the cables to silver cables and compare .... things like s's may sound like z's etc (a good track to test, is Prince's Purple Rain)
On my system, I have handmade interconnect cables called Silver High Breed Quintessence,.... these are as thick as hosepipes, and to me, they sound the best of the cables that I have (I have a box full of good cables and interconnects that I bought from auction)....
those in conjuction with my older hitachi ssx-102k lc-ofc copper speaker cables (as rare as hen's teeth now) connected to my B&W DM2 transmission speakers sound superb
If you have 'old' ears, let you teenage children compare, and they will tell you that cables do make a difference
