Outdoor storage box for a bike?
cyberknight
My store has a hole cut in the bottom and i installed ground anchors with a head that snapped offso a tea leaf cant just undo it , it also sits below the base so you would have to lift the store out of the way to get at them , doesnt stop a determined tea leaf that comes armed with bolt cutters of course attacking the chains but it sure does make it harder for them .
sasquath
And are they using a masonry bit ?
This https://www.powertoolworld.co.uk/me...xOd0eN-9HV7yFMDPacUQyG0a6LHkBjBAaAkMFEALw_wcB
Vs this
https://www.ebay.co.uk/itm/254988401348?epid=19046141838&hash=item3b5e7e3ac4:g:2RkAAOSw2CVgsMrN
Using the same 12mm masonry bit, new bit for each drill.
Parkside won by 10s drilling 80mm deep hole in hight grade concrete.
cyberknight
Deeble
An extra large outdoor storage box from Argos has an inner width of 130cm. With the front wheel turned do you think that's going to fit a bike in? Height and depth are fine. That's £160.
The range says same external width but doesn't list inner width, I'm.guessing it will be the same.
Widnes
Vs this
OK
I have a hammer drill and masonry bits which manage just fine with concrete and brick
the first time I have failed it with this Indian Stone stuff
I have tried to different drill bits - but from the same set - and they are the ones that get used most
Are there different versions of masonry bits - and how do you tell??
Thanks
sasquath
OK
Thanks
Hammer drills with normal chuck have very weak hamer, also cheap drill bits can be horrible.
Assuming you have non SDS drill:
Use these bits.
https://www.screwfix.com/p/bosch-expert-hex-shank-multi-purpose-drill-bits-5-piece-set/759ky
Use low speed gear if available, keep speed to 1/2 max speed if not.
Make a puddle of water to keep bit from overheating.
For SDS drill(some without hammer only mode are as whimpy as non SDS)
Buy Milwaukee or bosh bits, cool with water if needed.
Deeble
I think even the extra large storage boxes are just too small. Alternatively, could I squeeze one more in here? Bikes are deceptively long!
