wiggydiggy
everyone that ever rides with a club or group. but heck, ignorance is bliss.
Situation: Tongue in cheek comment results in slight superiority complex
Solution: Make gesture of own behind back
use your left hand behind your back to indicate to other riders you are pulling right. It avoids misinterpretation of your intent by motorists.
I always thought that you should do that point to warn other cyclists of obstacles on that side of the road. Such as a parked car, in the uk You would use your right hand behind you back to point left, and then you indicate right to pull around it.use your left hand behind your back to indicate to other riders you are pulling right. It avoids misinterpretation of your intent by motorists.
The signal isn't intended for car drivers so their ignorance is welcome. The average cyclist would be well aware what the signal means.The average car driver or cyclist would not know what that signal means, and most likely think you are flicking them off for no reason.....
What if the person seeing the signal was an exceptional driver but a poor cyclist?
They would know to wait for the cyclist to finish their overtake before checking to see if it was then safe for them to pass both cyclists.
Would this be the same as if they were a poor driver and an average cyclist?
No as although they recognise the signal their poor driving skills mean they run both cyclists down when they attempt to pass.
If two exceptional cyclists wanted to re-turf a playing field measuring 800 square metres and the maximum payload of their lorry was 1.5 tonnes, how many fish would there be in Alaska?
There are no fish in Alaska, Sarah Palin has shot them all.
Would it make a difference if the moderate cyclist in the red shirt had only green sweets but wasn't sharing?
No, nobody likes the green ones anyway.
You know I'm right.
