ren531
- Lancaster uk
Been testing out a modified partial chain case I made for my commuter bike at the start of this winter I am using a Sram S7 hub gear and it would only really work with a hub gear or single speed ,in the past the amount of road filth that got on to the drive chain was just a filthy mess ,so I bought I plastic hockey stick chain guard cut it down made a back for it out of 1,5mm ply ,added some builders DPC to keep spay from the back tyre away and its done a great job never cleaned the chain all winter only adjusted the chain tension twice instead of once a month ,so a lot less wear going on and it still looks quite clean .I guess its cut out about 90% of the road filth out ,it protects the chain from the front wheel spray and most from the back wheel and does not make rear wheel removal anymore difficult ,it doesn't improve the looks of the bike but its very effective .The whole thing is held in place by the bottom bracket shell and nothing else so easy to remove if I want to ,I put this in the commute section because its really only something that would be used on utility bike and I hope it may be useful to others who are fed up of all the mess on their commute bike ,I have done 1350 miles in all weathers with it this winter so far .
