Grant Fondo
- Cheshire
2022 PC cases are starting to go 'wood effect' like 70's hi-fi ... wonder if it will catch on?
Download a program called Rufus, currently version 3.21. Select and insert an empty 8GB+ USB stick. Ensure Rufus is 'looking at' that stick. Ensure you have the Win 11 .iso file you need. Select that file is Rufus. Rufus will then eject a pop-up asking you how you want to modify the iso as it is written to the USB stick. This will enable you to install 11 on anything, just about.Tried installing Win 11 on my 2016 laptop today, cpu not good enough as a '6 series' Intel ... shall stick with Win10
A definite rant: wanted, found, purchased, a half-decent mini-PCIe wifi-bluetooth combo card for the Asus S200E laptop. All installed, no BT. Faint, familiar alarm bells were sounding. Yup, this Intel card can only have the BT part activated by whoever is building the system, for some fiddling regulatory reason. Tried fruitless for some time to access a driver, to no avail. Just to increase general irritation, if I fire up a live Linux system on it, the Bluetooth is detected and fully activated without issue.
To be fair, it doesn't. But why would it ever need to be this way? Certainly shows where Linux can lead, though. Will investigate a more modern 802.11AC/BT card, which will hopefully be PnP.That's annoying ... no doubt it mentions plug 'n' play with that card?
Solved it, I think. Did some more digging and found a driver lurking in the repositories for a certain model of Dell XPS13 laptop. Unusually, it didn't object to being installed on a non-Dell machine, but then it's really an Intel driver anyhow. Will test it properly for function today.
The only downside to these things is the growing collection of slim 2.5" 500GB hard drives...
My main desktop has a 1.5TB secondary drive, trying to get through sorting everything to fit on that! If I had a larger case, I'd use the little drives as a RAID array. But then I still have 2x1TB 3.5" drives that would be better for that...Get a Pi or old laptop and make yourself a NAS box.
