Pedalling heavier over night
Scottmartin99
I’m interested to get the view of you experienced cycling folk on here.
I purchased the electric Carrera Crosscity Halfords bike 6 weeks ago. I absolutely love it because it’s so low impact on my knee that I barely know I’m riding. However, around 3 days ago, the peddling suddenly felt heavier. Almost like something was pulling it back as I peddled. I pumped up the wheels, put oil on the chain and the breaks where aligned. yet still the same problem. I noticed that when I’m NOT peddling and moving, the bike feels perfectly fine. When I peddle without the electric motor on, it was fairly heavy before, now it feels 3 times heavier than it did before.
Halfords are looking into it, but I’m keen to know what you guys think it might be and if you think it is something I might be able to fix at home.
I look forward to your replies and stay safe my friends.
Scott
boydj
Paisley
Do the wheels spin freely when lifted off the ground?
My wife has one of them so I ride it sometimes
I have never had that problem so it is not normal (obviously)
I was wondering if something is rubbing against the pedal/cranks or chain at some point. If it freewheels OK then the wheels and brakes must be moving OK - so it must be something else
I would suggest that you make sure Halfords fix it - and if they give it back and it still has a problem makes sure everything is in writing. I have had problems with Halfords before - but when I started documenting everything they were OK.
Anyway - great ebike for its type - I was amazed when my wife got it as it was soooooo much more powerful than my old Powacycle (OK that was 10 years old which may have been the reason!!)
If you have any problems and want me to try something out on mywife's bike - let me know!
Pale Rider
The Carrera is a great ebike for the money, but there are persistent reports of problems with the Suntour hub motor.
I know Halfords has replaced quite a few.
All will be well if you get a good one.
Scottmartin99
Scottmartin99
Thank you for replying. Very kind of you.
Yes, with my limited knowledge, I assume if can only be the pedal or cranks.
I took it back to Haldords and was treated appallingly. After riding it everyday for 6 weeks, I told the guy that I noticed a significant difference in its performance overnight and 2 days later my left knee problem started coming back. The cycle guy at Halfords said there was nothing wrong with it. I politely insisted that there was something not right. He picked up the bike, put it over the Barrier (2 meter virus Barrier) and said “I can’t do anything for you” and walked in, locking the side door behind him. Disgraceful attitude, especially after I was respectful, kind and cooperative throughout our conversation to try and find a solution. It will be my first complaint in many years against anyone. That was unacceptable.
Actually there is something you can check on your wife’s bike if you don’t mind. There is a bit, I’m not sure if it should be slightly bent onwards or not. It’s Sending photo now. Thanks again for your help
Scottmartin99
Scottmartin99
Thanks. The peddling is heavy even when the motor is off. Do you think it could still be a problem with the Motor still? As you can tell, my knowledge isn’t very good 🙂
Scottmartin99
Scottmartin99
Are you sure the motor is engaging at the right assistance level ?..... It could be that its stuck on a low level of assistance.
The motor seems okay. It is stronger on each level. It’s just harder to pedal than it was before, whether the motor is off or on. The problem seemed to occur overnight. I’m working a little harder to pedal than I was.
Smudge
Somerset
You are going to have to go through everything, bb bearings, drivechain and gears, check tyres aren't rubbing on brakes or mudguard. Also check tyre pressures, a loss of pressure will make the tyres more draggy.
Scottmartin99
Scottmartin99
F
That’s what I was thinking too. I’m plumped the wheels, oiled the chain and got the brake pads aligned. So it’s none of them.
But I purchased the 3 year cycle car with Halfords. Plus, they extended the returns policy to 90 days, 2 days before I purchased it. So I’m trying to return it like for like.
Do you think a Halfords cycle worker could know there was nothing wrong with it, within 10 minutes, without stripping it apart?
Deleted member 26715
I'm not excusing Halfords as if this is the case it should have been clearly advised to you, but it could be that they are currently not allowed to take back bicycles, again slightly different but my son works in retail & they currently cannot accept any returns, they are advising customers to keep their receipts & the 30 days they normally get will be extended until they are clear to accept them. Do Halfords have a CS phone number might be worth ringing & asking, also might be worth putting in a formal email complaint, so at least the ball is rolling.
Scottmartin99
Scottmartin99
If there is a reason they can’t take items back then I would have been satisfied if he had told me that. I would have followed their current procedure.
Iv contacted CS about exchanging the bike. As soon as I get his name, I will put in a big complaint. It will hopefully help him change his attitude or change to a non customer facing position within the company
gbb
Peterborough
How do you feel in yourself Scott ?
I ask because when I was at my peak, just once in a while I'd jump on the bike, full of expectation for the ride ahead, get 5 miles down the road and quickly realise, it's just not there, I'm carrying a virus or something, I feel I'm struggling. I'd turn round and rest up for a day or so. There can be something health wise, not necessarily really bad, in you that you dont realise until you start to exercise. Exercise just tips you into the red perhaps.
Next ride out, a few days later, no problem
Scottmartin99
Scottmartin99
Im lucky really that my health is in a really good place at 41. I had symptoms of Covid a few weeks ago, and I felt tired riding the bike for a couple of days. It passed and I was back to normal before I felt this pedal resistance thing started to happen.
