Pedals
Y
YMFB
Most SPD pedals can be adjusted to limit the amount of float.
But if you need new pedals Shimano M520's are pretty good.
They are not worn out, and unfortunately they can’t be adjusted for the sideways movement.
im looking for something with a larger platform and longer shaft length.
Wolf do some, not as long as the SQ Lab XL
Y
YMFB
I really want something with a larger platform than the 520s and a longer shaft if possible
Sharky
Kent
Have you considered pedal extenders?
Available in various lengths.
It's not as rotational means relating to a circular or 'rotating' movement around a fixed point. Float is just the lateral movement of your foot whilst you are clipped in.
Nope. Float, as it pertains to clip-in pedals, is the available rotational movement of the cleat in the pedal. It can be 'free' float or 'spring loaded' float and is measured in degrees.
