Peugeot 103 crank removal
Rebuild1961
Glenolden,pa
Is there a easy way to remove the outer plastic guard without removing the crank?
Spain
Take a photo from the other side of the crankset.
Ajax Bay
East Devon
It looks as if you might be able to poke the five fastenings off from the inner chain ring side, without needing to remove the inner, even. Bear in mind that this plastic guard is old and that type of plastic gets brittle with age. As @DCLane implies it's fastened by simple push in clips, of plastic (same vintage). The chance of removing this without breaking at least one (of the five) is low (ie <50%) imo. Consider not removing it if you want the finished bike to have it.
Rebuild1961
Rebuild1961
Glenolden,pa
That sounds good. I can work around it. Just need a little patience. Tks!
Rebuild1961
Rebuild1961
Glenolden,pa
Should this plastic shield move free or should be locked in place?
Essex
They usually have a pair of little tabs that click around the spokes to hold them in place... that is until they get removed by folks who don't like 'dork discs' :smile:
If the tabs aren't there, I'd heartily recommend removing it and just making sure that the rear mech limit screws are set correctly - you can cut them away with a Stanley or craft knife or a pair of snips.
Rebuild1961
Rebuild1961
Glenolden,pa
Ok I will check for the tabs (they might be broken off) I will keep this since it is original and also guess the best way to clean this would be Dawn dish soap and a soft toothbrush.
