What apps do you guys use? After a good route planning app (too impatient to get maps out) and also after a timing app that records avg speeds and such.
Garmin Connect (if you use a garmin device), Strava or Map my Ride although whilst the apps will record data like time and average speed your better off using their web sites and saving the routes which then you can access via the app on the phone.
I'm currently using cycle meter but it isn't very accurate and my same daily commute can often end up a mile longer or ten to twenty feet differant in altitude gain/loss and the ride profile is very differant
Strava but all of the apps are unreliable on elevation. If you are really wanting better accuracy, get a garmin. Whether it's worth the financial outlay, only you can decide
My Tracks - it really is very simple and quite good. Mate has a Garmin and we seem to almost get the same results. I've had not of the issues mentioned, neither have friends.
