Pinarello Angliru.
Illaveago
Illaveago
I have got my stickers and started to apply them . Trouble is the down tube one is going downhill slightly. I will have to see if they can make me another one. They are not waterslide ones so they are a bit tricky to line up.
T4tomo
Looks fine from here looking at it on a phone!
Illaveago
Illaveago
Oh I am a numpty ! I had noticed that the letters appeared to be lifting and air bubbles were appearing. I kept on smoothing them down but they kept coming back. The stickers were rough textured and I thought that I would have to spray several coats of clear 2 pack over them. As I am thinking of removing the sticker that went wrong I thought I would try lifting it to see if it was stuck. I I pulled on the plastic I noticed that the letter was still stuck on the frame. The rough clear vinyl was just the carrier material and needed removing. The stickers look a lot better now!
Illaveago
Illaveago
It is getting there slowly. The bike has come a long way from the corroded measled bike that I bought a while ago. There were some parts which were seized but have managed to free them. The light at the end of the tunnel is starting to get bigger. I have had to spend a bit on parts , paint, and stickers. The printers had to redo my artwork but used them to produce the correct fonts and size. They have cost £45 including vat which I don't think is bad as I couldn't find them anywhere online.
Illaveago
Illaveago
I think I might have added to today's record temperatures as I took my frame outside with a heat gun and removed the sticker. I carefully measured where the new one should go and stuck it on. I am now happy!
Illaveago
Illaveago
Sorry for the gap but a few holidays have intervened, mine and my friend's, I use his garage for spraying. I'm going to have to thoroughly clean my spray gun as red tends to hang around in them for a long time and I don't want my clear lacquer having a pink tinge. I have also been waiting for my brother to finish the gold lining on his Holdsworth frame. I will hopefully lacquer his a day or so after mine.
Hopefully once this has been done I will be able to start fitting my bike up.
Drago
The Urban Fringe
Its not really Italian, more of an international effort. Not that it's in any way a bad thing. The frames are painted in Italy IIRC, which might explain the lack of durability.
Sympathetic job on the refresh there. Looking forward to seeing the old bus finished.
Pinno718
Way out West
Sorry for the delay. I have to arrange a day when I can spray the lacquer round my friend's garage, I also have to spray my brother's frame soon after.
I have also been a bit side tracked by 2 other Italian frames.
I'm impressed. The paintwork on the Galileo was far too ornate for me to even entertain replicating it and even if the Angliru wasn't as complex, it's still a tough ask; well done.
You could have gone to your local vinyl sign writers. I can't remember what the material was when I used them eons ago but it was very much like the water transfer you used to get in those plastic kits.
Have you uses 2k lacquer before?
