Andywinds
I only tend to move forward when climbing, I've taken this from MTB techniques over the last couple of years. And also on some sprints. There is no way that I would want to do this for more than 10 minutes. I have just moved my saddle back a little, I've also used that technique where you dangle a line from the base of the kneecap so it intersects the pedal axle.
Notice what's happening, the front rider is in close to maximum effort - as a cropped picture it's hard to tell but it could be the early part of a break when putting some time into the peloton is priority, before settling into a more sustainable pace. Then everyone sits back a little. You simply can't ride (or race) 200+ km sitting on the nose of the saddle, unless you enjoy a tender undercarriage (or worse). The pelvic bones need to be supported to avoid excessive compression of soft tissue. Females generally have a wider pelvis, hence female specific saddles are a bit wider at the contact point for pelvic bones. So, use manageable gears, sit back and enjoy more.
