i'm going to treat myself to a pair of prescription sports wraparound glasses, but would like some advice on choice of lens:
the optician i went to stocked adidas sports frames. i chose the ones i liked, but i have a choice of lenses, basically with or without optical inserts:
choice 1) is without the inserts, the lenses are tinted and made to my prescription. so they look like a "normal" off the shelf pair of sunglasses
choice 2) is with inserts, which i had not seen before. it is the same frame, but an insert which is made to my prescription clips inside the frame. the lenses of the main frames are interchangeable so different colour tints can be put in
the optician recommended the inserts (which were cheaper), saying they are more versatile and that with option 1 vision when looking to the side would be slightly blurred as the you do not get the prescription all the way round the wraparound lenses
does anybody have these inserts? and what are they like to wear?
do you see the sides of the insert ? and can others see the insert from the front if you have light lenses in the frames?
the optician is getting some of the inserts in next week for me to go back and see and try them, but any advice from people who use either of the above would be appreciated
