Presta valve in Schrader hole?
Can it be done? I have a spare rear wheel that takes the Schrader (car) valve, but I'd like to use it with a Presta tube. Bike uses Presta valve on the front wheel and I don't want to end up having to stock / carry round 2 tube types).
Currently, the Presta rattles around in the hole when offered up, and when I tried inflating it a little, the valve protrudes through the hole so that it won't seat, even when the lock ring is wound right down to the base of the valve.
Is there an adapter that will reduce a Schrader hole to take a Presta valve, or is it a no-go?
Steve Austin
The Marmalade Kid
Mlehworld
you can get a little bit of rubber that fits in the hole to fill the gap, but it will be fine even if you don't use the little rubber widget. I have no idea where you can get one though.
Scwalbe inner tube locking screws have a two step part that fills the gap too, so it sits flush.
it'll be fine without either though
beanzontoast
Cheers steve - I'd wondered about putting a spare lock ring on the valve and using one each side of the hole in the rim. It might hold the valve steady - but do you think it might cause problems with the tube at 116psi?
Pete
I, too, was told by a LBS that a sort of grommet was available, though they didn't have any in stock, and in the end I used the 'lock ring' dodge as mentioned above. I was warned, however, that if a rim is drilled for Schrader it may not be able to withstand typical presta valve pressures, adapter or no adapter. This may be a matter of opinion, still, I wouldn't trust the setup over about 90psi.
Better to invest in a new rim.
P.H
I do this with all my rims, so I can use either tube. I have some rubber grommets that came from Gearshift, it doesnt look like they're available now.
My latest Mavic rim (717?) came like this with a plastic insert. I got it from Holts, in Derby, so it'd be worth ringing to see if they have any spares.
alfablue
for anyone else, they are available at John Street Cycles for £1 each - http://www.sjscycles.co.uk search for "Mavic Rim Valve hole drilling converter insert - Schraeder to Presta"
Steve Austin
The Marmalade Kid
Mlehworld
you mean £3.50 dont you?
You forgot SJS postal charges. They have got better, but 2.50 is a tad excessive for a rubber gromit. Most LBS should have them
alfablue
Yes, it is steep for postage for something weighing about 5 grams!
bonj2
i don't know why you're all whittering about grommets and what not, i just put my presta tubes in my mate's schrader hole no problem, just do up the little metal collar thingy and it's fine.
alfablue
Another Bonj wind-up I think, but if you do this the tube will eventually fail as the valve seperates from the tube at it's base - been there, had that
bonj2
That's a bit strong - "I put a presta valve in a schrader hole" - therefore must be a wind-up!
You say 'eventually'. I think it will probably puncture by other means before that.
