Quick-fit rear pannier/luggage rack
Magpies
Cambridgeshire
Any suggestions please for a quick-fit rear pannier/luggage rack that can regularly carry 5-10 kgs?
I need to regularly swap the rack between two different road bikes (both with rim brakes, both fitted with bolts/threads for rack mounting). Something that is quick to remove and re-fit would be ideal.
I considered "beam" type racks that clamp to my seat-posts (they're not carbon) but the reviews are mixed. My rides typically include pot-holey UK roads, and I want to avoid lateral shifting of the rack/luggage.
Thanks!
If you don’t like the beam ones, Just get two Tortec ultralight racks and leave them in situ :okay:
Magpies
Magpies
Cambridgeshire
Thanks!
I was hoping to get a rack I could leave off when leisure riding but reattach when commuting.
The Tailfin looks great but is way beyond my budget.
Thanks!
If you’re competent, I should think you should be able to remove and reattach a rack within 30 minutes. Or the Tortec ones are light and strong. Won’t have much effect on bike weight without panniers
MontyVeda
I figured I'd only fit the rack when i wanted to use it, but after its first fitting, I thought feck it, i can't be arsed with that faff everytime i want to attach a pannier. I'm with Vickster... just put a rack on each bike... you won't notice it when you're riding.
raleighnut
On 3 Wheels
+1 for the Topeak beam rack, on a couple of my bikes I can wriggle the clamp through the seat stays above the brakes and clamp it to the seat tube.
