Re-using a chain pin/rivet
grellboy
Just removed chain to clean it. Upon Googling, it seems that it is frowned upon to re-use the chain pin you have pushed part way out. Instead it seems consensus is to remove the pin entirely and replace with a new one. I'm sure I've reused a pin before without any major consequences. Any opinions will be welcomed.
Drago
T'is said you're not supposed to do so, but I always have done.
Done it literally hundreds of times, with no comebacks. I prefer a quicklink, but have no issues with re-using a pin as long, of course,as you closely check it to see that it stands proud slightly on both sides, just like all the other pins.
davidphilips
Phil Pip
Onabike
Like quick links myself but have joined many chains by reusing pin with no problems, far as i know you need to be very careful with the shimano chains that are peened, Usually any thing over 8 speed shimano is a risk if reusing a pin best avoided, looking forward to a reply by yellowsaddle as any advice he gives is well worth taking.
Venod
Eh up
Yorkshire
I use quick links nowadays, but I have reused the pin on many occasions including 10 speed with no adverse effects.
iandg
Always used the same pin when constantly changing chain length to cope with different chainrings and sprockets when changing gear on a fixed wheel.
