I expect such information is readily found in the highway code.What's the legal requirement re rear lights ?
I know there was confusion a few years back.
Is it still a static red , rather than flashers ?
They can look but not see as @Tim Hall suggested.Got to say more about the drivers than the cyclist. I've still had drivers pull out on me, but to be honest, I reckon most of them see me but underestimate my speed and pull out anyway. The last guy actually made me laugh as he desperately tried to ignore me as I overtook him again.
A helmet. With indicators. With brake lights. With a one hundred and sixty pound price tag. Include me out.
Ok.A helmet. With indicators. With brake lights. With a one hundred and sixty pound price tag. Include me out.
How steady is the extender in use. I removed a similar one from the front because it seemed to "bounce" whilst in use.As per @Slick's post, the Lumos helmet has a red rear triangle embedded - a chap passes me daily with one of these going day / night / all seasons: https://www.amazon.co.uk/Lumos-Kickstart-Helmet-Charcoal-Black/dp/B01N273KZT
I doubt a rear bike light randomly attached to your helmet would work very well though - you're likely to run the risk of dazzling drivers if the angles are wrong (or as you are moving your head to look around).
If your rear light(s) aren't well positioned to be seen from a good distance, think about fitting an extender to your seatpost to move the position using something like this:
https://www.tredz.co.uk/.Topeak-Bar-X-Tender_4995.htm
I have a similar one on my commuter to bring the light out from under the saddle and raise it above the arc of the rear mudguard.
Cheers,
Shaun![]()
In Japan you have to prove that you have somewhere to park a car before a permit is issued allowing you to buy one.Just one steady red light is enough. Please stop littering yourself with lights. You are not safer.
The current trend for more lights is just telling the car user the wrong story. "Look out, driver! I'm really special! You need to pay loads of attention to me and whatever you do don't knock me into the hedge! Beware! I'm a cyclist!"
All the flashery and ultra-white bulbery just annoys the car-user, makes him unsure how to take in all the info, and makes him more likely to make a bad decision and run you into the hedge. And meanwhile, cyclists dress up more and more like some hi-vis freak show circus act, looking less and less part of the flow and more and more "special".
We need to reverse this nonsense before it gets out of hand and just follow the Highway Code's suggestions.
Plenty of evidence from around the world that less lighting is better. Try cycling in Japan, where there are narrow city roads littered with telegraph poles and other obstacles. After dark, most bikes only have a red reflector on the back, even if the law requires a small red light. Car users know how to share the road with the cyclists, and accidents are remarkably few.
I think they are good. The odd driver still appears to try his best to pretend not to see you but I think it seems to happen less. The first 20 minutes of my commute is unlit country roads, and I feel even oncoming drivers are now more prone to dipping their headlights as they usually are for "Just a Cyclist".not seen those before
Yeah, that could be an issue for some, there is one section on my commute as I come out the country lanes and into town that is downhill and I do go on the drops, but it's no more than 5 minutes probably a bit less of a 60 minute ride. If you spend your entire commute attacking hills and on the drops this one might not be for you. I have it adjusted to give me what I feel is best visibility in relation to my riding position.I've seen one 'in the wild'. Most of the lighting was redundant at the rider was on the drops.
