Debian
- West Midlands
Howard said:You can lock your front wheel? In the dry, I would have thought this would see you going over the handlebars. And in the wet, god knows. Forwards slide? Perhaps you aren't positioning your weight properly.
On the understanding that 90% of your stopping power comes from the front wheel, and that you can't lock it, discs will stop you quicker because the limiting factor is not the grip between the wheel and the road, it's the efficiency in which the brakes turn kinentic energy into heat.
A mute point then, and pehaps my physics is no longer up to scratch, but I would have thought the definition of "good brakes" is a system that is effcient at turning kinetic energy into heat. When you lock your brakes, they aren't doing that anymore, so just because you can lock them doesn't mean they are any good.
From my experience my rear discs very, very rarely lock - most of the time they are very effciently turning my momentum into heat.
Yes, I can lock my front wheel. That isn't to say I do
I do understand about braking efficiency and all I was stating was that I've found no perceptible difference on tarmac between discs and rims.
If you can't lock your rear brakes then they're not very efficient, it should be really easy to lock the rears under any normal riding conditions which is why you should only use the front brake in emergency stopping conditions. The limiting factor is the frictional coefficient between the rubber and the tarmac, brakes will always be more efficient than the grip of the tyre onto the road.
