Dayvo
just passin' through
- 59° 50′ 5.55″ N, 10° 47′ 41.89″ E
Catrike UK said:+1 there is no advantage to discs.
Disagree! They are far better/safer for braking in wet conditions!
Howard said:
Rykard said:Genesis Croix De Fer (sp?) ?
HLaB said:You get predictable braking performance from rim brakes in the wet too; you can predict there going to be sh1te.
Dayvo said:Disagree! They are far better/safer for braking in wet conditions!
summerdays said:Am I right in thinking that any drop handled bike with disk brakes only every come with cable disk brakes?
Catrike UK said:No, a properly set up rim brake with the right pads is equal to a disc brake set up. The only time a disc set up will be better is in extreme mud.
Steve Austin said:Yes, No one has created a hydraulic braking system that works with road brake levers yet
Dayvo said:What about wear and tear?
Out on a long day's ride in wet weather when efficient braking is essential, you don't want to be worrying about whether you've got enough rubber left on your pads!
Here's a guide for the OP!
http://www.bonthronebikes.co.uk/help/advice-on-buying-brake-pads
Catrike UK said:I concede that rim brakes cause wear to the rim, as to your second point, would you go out with worn out disc brake pads? Or cracked or warped discs?
