rogerzilla
The radial front wheel is a problem for pump heads. I find my Joe Blow head goes in ok on one side of the wheel, but not the other.
You are absolutely correct. I ended up taking the narrow chuck off the bad pump and putting it on the good pump. Problem solved.I got an el cheapo floor pump from either Lidl or Aldi for a fiver. But it's rubbish. Cheaply made using very hard, brittle plastics and the head keeps coming off.
I bought it as a spare because it was just a fiver.
I'm guessing you have more trouble with the rear wheel as the spokes are crossed and there is less room, the front wheel is a lot easier as the spokes are radially laced.
I actually had floor pump before Brompton. It still works, just not the best. The issue is quite high pressure required for Brompton tyres. For any other use (and for other bicycles not requiring high pressure) floor pump is fine. Lidl pump has surprisingly similar look to Joe Blow. I don't have both pumps, so can't compare height and all, but from first sight it looks quite similar. The most similar feature is the handle. It is almost identical. Gauge is much bigger on Lidl pump. Once I will get a chance I will take some closeup pictures and people with other types of pumps will be able to check for themselves.Who buys cheaply has to buy twice. Classic. You bought cheaply, had to buy twice and bought cheaply again. Seems you have not learned the lesson yet.
Typically, that's the idea behind products like that. Fake iPhones follow the same strategy.Lidl pump has surprisingly similar look to Joe Blow.
That says absolutely nothing about the quality of the pump (neither to the positive nor to the negative). But you can assume, that it not possible to build something of the same quality for 25% f the list price.
) this counts only for a small amout. If I remember correctly it was aroundish 10% (may be wrong - in every case it was a suprisingly low number). In all other cases the items were not cheaper than comparable products of comparable featureset and quality (or even the same products) from other sources. Sometimes (again I do not remember the exact amount, I think it was aroundish 30%) they were even more expensive. Plus typically, in comparison to a reputable standard product, the items lack interms of either design, finish, featureset, functionality, endurance - basically everything but safety.
and laying out the mechanics behind it helps me not get cheated by it.
Why spend money on a mini pump that you will hardly ever use if you already own one? This would really be burning money. The pump will clearly not be better than the stock Brompton one (which is NOT bottom line, I can guarantee you from experience with a lot of mini pumps of various price ranges) but pretty safely way worse. You would not win anything but loose money. Buying something that you don't need and does furthermore not even open new possiblities just because it's cheap is seductive but not clever.I am actually thinking to buy another Lidl product- Crivit mini bike pump. It is probably something I would rarely use and in case of a flat my most likely action is just to fold a bike and use public transportation. On other hand one included with Brompton (that was hanging on a metal bits of a frame) is absolute bottom of the line. I guess in absolute emergency it is better than nothing, but come on...
I would not call it arguing, rather discussing. And - at least for me - it is not at all about "winning".I guess we can argue about everything forever.
The pump came alive trough the German discount bike brand https://www.monz-international.de/index.php/en
It really depends. Lidl, Aldi etc. obviously do not produce the stuff they sell but buy it from producers in big batches (which can lead to an interesting offer pricewise). Sometimes they sell overstock and somtimes there's a reason why there is overstock in the first place. Sometimes they get products that look like the normal ones but are customized and often have a more limited feature set. And sometimes they have things branded with their own brand and specially produced (like most of the medion stuff Aldi sells) - some of them may be good, some of them not so much. But in general the products are produced to target a low price - so sometimes got get astonishing value for the money, sometimes it turns out that they cut corners. You never know in beforehand.The pump has Lidl owned "Crivit" logo molded in the handle. So it is a bit more effort from Monz. Also when on Monz website https://www.monz-international.de/images/sortimente/fahrrad/pumpen-02.jpg they have very similar pump with tiny difference (like the color of gauge), so I assume perhaps they sell the same pump with different retailers? As far as Lidl goes with their own brands... Over the years I had many products from them and some of them were really great at decent price.
Absolutely true. Still the already cited common law of business balance is unavoidable.On other hand money paid for a product is not always point to the quality.
