bobg
- Crosby Merseyside
Just had my first stab at it and it (eventually) turned out OK but I'd appreciate help with the following.. I have an ancient truing stand which is fine for resolving run out but no way ( apart from "eye") to measure ovality.
1. All the other stuff I read suggests centring the axle before redishing, I fear I'm having a senior moment, but why?? Surely the aim is to centre the rim ie remove bias on the driveside. Can't centring the axle can be done afterwards??
2. I was very careful to stacken off the driveside spokes one complete turn before tightening the other side a similar amount. No matter how careful I was with the driveside slackening, the wheel went out of true. Should I retrue it immediately before or after retightening the other side?
3. Is one spoke nipple revolution at a time too cautious? I had to repeat the process 6 times to finish the job
4. Does a dishing tool fit on to a truing stand or just bolt to the axle in some way? ... Has anybody made one??
Thanks in advance
Bob
Thanks in advance
Bob
