Repairing my...bib shorts
livpoksoc
Basingstoke
I might have accidentally put a pair of my bibs in with some jeans & now they have a chunk out of them. Has anyone bothered repairing their shorts before and is it worth it, or should I just bin them and get some more?
Supersuperleeds
Leicester
I keep my worn shorts for winter when I will wear a pair of bikesters over them
ColinJ
Puzzle game procrastinator!
I have a pair of bibtights and a pair of baggies without pads so I wear worn/damaged bibshorts under them for the padding. It helps to keep warm in very cold conditions.
I sometimes wear old shorts on the turbo trainer too.
Glasgow
I don't wear cycling shorts, just leggings: in winter you sometimes need two pair, so the tatty ones go under the nice ones ^_^
palinurus
Velo, boulot, dodo
Watford
I patched a pair with some Ironmend once- it's designed for wetsuits but you can patch lycra with care (you cut out a patch and iron it on, using some protective paper- supplied in the tube- to prevent the iron melting your shorts). I've heard Gore-tex repair patches can work too but haven't tried them.
Nigelnaturist
Pontefract
Nothing under, unpadded tights over, like altura winter cruisers or running tights
Not entirely true, I modify lycra leggings and wear these under the shorts though the pad is still next to the skin usually warm enough down to 3-5C colder than that leg warmers and if really cold winter tights/trousers.
HarryTheDog
Basildon Essex
I have had cycling tights repaired in the past by my mother in law with bits of a old pair of shorts. Nowadays I wear Assos tights and Rapha + Assos shorts which get repaired for free!. I have used the service and because they took so long ( sent to switzerland) they gave me a new pair instead to keep me happy.
Depends where your chunk is missing from, if its from somewhere it will chaff I would not bother. Somewhere on the leg would probably be ok.
Crotchless leggings then, do they not rub the tops of your legs
livpoksoc
livpoksoc
Basingstoke
Thanks, the smag is on the outer thigh, so not an issue, another pair of shorts I have, the stitching ont he chamois is coking loose, i assume it's ok to get that under the sewing machine to fix?
U
User6179
My chamois was loose on a pair of shorts so I put a few stitches in it to keep it from moving , I used some nylon thread and ended up with a cut in no mans land :biggrin:
