Replacement Fork - Ribble fork on Cube - Help with measurements
kenam
Hi,
After posing about some general comments on fixing up my broken Cube Peloton 2010, I need help with comments in bold, below
I am hoping this fork will be a similar replacement (but I cannot be sure of the original fork sizes).
Its listed as
  • Compatible with 1 1/8 45 x 45 Integrated headsets (Dont know what 45x45 refers to)
  • 300mm Alloy Steerer (Will this need cutting? or is this standard)
  • Tyre clearance up to 23mm (A little narrow, but my normal anyway)
  • Rake - 45mm (I think this is common enough to not be a concern)
  • Compatible with 9mm Quick Release axles (Hoping this is standard!)
I have a FSA No.10 (Semi integrated) headset - that states:
  • For 50mm OD head tube
  • 1.1/8" steerer
  • Alloy custom top cover
  • 5/32"×20 retainer bearings
Would these components be compatible?
Thanks for any help!
raleighnut
No one has integrated bearings and the other has 'semi integrated' so different headsets.
