Replacement front light (dynamo)
ldsau93
Bristol
Evening. My front dynamo has given up the ghost. I'm not knowledgeable on these things - do all front lights have the same connectors? Pic enclosed of the dead one.
andrew_s
Gloucester
The standard dynamo light connectors are 2.8 mm spade terminals, which those look like (subject to being unable to judge the width of the terminals on a photo).
You should just be able to bolt on a replacement light and plug the existing cable in, provided it's in good order. The exception would be lights that come with a pre-installed cable on them, which are mostly at the more expensive end of the market.
albal
Dorset
Just recently purchased sinewave beacon. Awesome piece of kit. Expensive - yes. Quality product. My two previous B+M front lights didn't last, hence forking out for a superior product.
Ming the Merciless
There is no mercy
Photo Winner
Inside my skull
If you get another B&M light then the wires with current connectors will work. The SON front lights have a fixed wire , so you'd need to add new connectors on those for the Dynamo end.
In short Dynamo lights from different manufacturers do not have the same connectors.
U
User169
Nice piece of kit, but the symmetrical beam isn't ideal for road riding and illegal in at least Germany (where I do a reasonable amount of riding).
