Replacing a shifter cable..
Right..
I need to replace the shifter cable for the front derailleur on my Triban 3; I've never done this before so I have a few questions:
1. What type of cable do I need to buy? Links anyone? or all cables pretty standard.
2. I'm assuming the existing cable housings can just be re-threaded?
3. Any tips? It's Sora btw.
Thanks for any advice.
C
cyberknight
C
Chescadence
outers are cheap as chips may as well do the lot.
when i did my right hand i had to have it in the "fastest" gear click on the shifter so the cable hole in theshifter was visible on the outside of the shifter then i just pushed the old cable out
https://www.google.co.uk/search?q=shimano 2300 tech docs&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-GB:ohmy:fficial&client=firefox-a
Thanks for your help! Much appreciated; exactly what I needed!
I'll order the parts and have a good read of the tech documents!
Thanks again,
C
Globalti
LC, don't grease or oil the cable; it needs to run almost dry inthe outer. At the most you could wet your fingers with some chain lube and run the cable through them.
