A good case for disc brakes.Some rims have internal cavities that show up as holes in the braking surface when you hit the wear limit, rather than a groove that vanishes. View attachment 387300
My experience is that the rims actually fails at about 0.7 mm, so retiring it when less than 1 mm seems right.
Your rim looks like it's got plenty of life left.
Rims also used to be thicker when they were simple extrusions bent into a circle and pinned at the joint. When you take the same extrusion, replace the pins by a weld, then machine the weld smooth, along with the rest of the braking surface, you take off quite a lot of thickness and wear life.
I call them "pre-worn out rims", but there's no choice these days.
Or hub brakes.A good case for disc brakes.
Anything but rim brakes. An antiquated system that is well past it's sell by date.Or hub brakes.
I wonder if they thought about that ?I have fallen slightly behind in tech/spec racing. How do rim/disk brakes compare weight wise? I am not talking in GP terms of carbon and titanium stuff, but in common similar price range systems.
The wheel design to handle the disk forces must have different bracing/spokes, while rim brakes don't need this extra loading. Looking around at modern bikes I just don't see this. Either those disk wheels should be deteriorating soon when heavy braking is a habit or rim brake wheels were always way over designed.
