TheSoulReaver03
I too am finding it hard to visualize your problem but here's a belt and braces approach that I might start with.
Basics:-
Pump the tyres up. Each one will probably need about 80psi in depending on tyre size, wider less, narrower more
Make sure the seat height is right for you
Make sure the seat is not too far back or forward (knee over pedal as a starter guide)
It changes into all gears, adjust limit screws on front and rear dérailleurs if it doesn't
Fault checking:-
Check the whole frame and forks for dints, bumps, cracks and rub marks near the wheels
tighten the quick release levers and make sure the wheels are fully in dropouts
spin each wheel and watch if it's straight by observing the space between brake block and rim
Spin the cranks by hand, make sure there's no stiffness or notchiness
Make sure the rear freewheel is free by pedalling backwards
No play in the hubs (you already did this)
Lift the bike and move the bars, they should move freely no notchiness
put the front brake on and rock the bike, there should be no play in the headset
put the brakes on and off, they should release, check this by spinning the wheel after using them
Check all bolts to make sure they are tight
examine the chain to make sure it's lubed and there are no stiff links
Examine the tyres for bulges or splits
I'd start with that. Youtube will tell you how to do each of those things if you are not sure.
I'll try to explain on more time.
I get on the bike. I pedal to a steady speed of 20 KM/H then I stop pedaling. The front wheel is giving off a clunking noise every time it makes a full turn. That silent clunking noise ( was louder when the inner parts of the hub were not replaced) is followed by something that kind of shakes the frame a little bit.
@gbb
Next, I lifted the front of the bike up while stationary and spun the front wheel while it was not touching the ground. This time it made sort of a scratching noise like it's touching the brake pads or the sides of the forks, but it's not touching anything, I've checked it. Although it's weaker, I still feel some shaking in the frame after that scratching noise. Although it does look like that the rim is going suddenly sideways then going back to its original position, but none of the spokes were loose last time I checked. (I guess it's not tyre pressure then.)
I believe this may be the culprit in slowing me down.
I hope you understand my problem now. I don't think I can explain it better. :\
EDIT : I've also lifted the rear wheel up and spon it, same situation as the front wheel. It's shaking the frame a little bit, but I swear to god it's not touching anything...
EDIT2 : The guy said they didn't really see anything wrong with the front axle. When I asked him why my MTB is rolling downhill faster, ha said he has no idea.
