- Glasgow
Or Marathon Ice SpikersIf you think Marathon Plus are hard work you should try Marathon Winters
It makes absolute zero differenceLot's of Schwalbe tires are directional (is that even a term?).
Check you have them on the right way - it makes a massive difference to speed & comfort!
Just something I read... Not from personal experience, honest!![]()
Naughty, naughty! But you managed to get Ian to 'bite'. Does the Hobbes' 'road' bikes do the "more dynamic" look?Lot's of Schwalbe tires are directional (is that even a term?).
"Why are so many treads direction dependant (sic)?
"In the case of a road tire the rolling direction is mainly important for aesthetic considerations. Tires marked with arrows simply look more dynamic."
https://www.schwalbe.com/en/profil.html
I wasn't trolling. The OP asked about Marathon plus tyres. My Marathon plus tyres have a direction on them (in black on the tyre itself, so hardly for aesthetics) and I have learned from bitter experience that it does make a difference if you fit them backwards.
(It also says it on the pages you linked to?)
I use them on 2 old MTBs, one used for touring & one for commuting. My tyres are big, currently running 2 inch ones on the tourer. I know nothing about "road" tyres and care less.
So, OP, check the directional arrows on your tires. It may make a difference.
Mmmm, fresh rubber
M+ great protection but lethal in the wet in my experience. However that is probably because I had them pumped to the max so they roll better............
Are they a bag of crap ? I wanrted some Conti Four Seasons but I dont have the wongaHope you like fixing punctures at this time of the year with those![]()
Your assumption of the cause of your slip is invalid. A tyre pumped to the max or left soft, has exactly the same grip on the same surface.
Your assertion is correct for contact with flat surfaces. However I think the issue is with bumpy surfaces. With these, a tyre pumped to the max is more inclined to leave contact with the road, at which point your grip is zeroYour assumption of the cause of your slip is invalid. A tyre pumped to the max or left soft, has exactly the same grip on the same surface.
Nope they are definitely squirmy in the wet and so are the Vittoria Voyagers I bought last year, they were even worse. Current Conti 4 Seasons however are much better.
There was no mention of irregular surfaces crossed at speeds where bounce is introduced. Hence, leave it out. The statement was simple: the tyres were more slippery because they were pumped too hard.Your assertion is correct for contact with flat surfaces. However I think the issue is with bumpy surfaces. With these, a tyre pumped to the max is more inclined to leave contact with the road, at which point your grip is zero
