Time Waster
Just been into loft for something. The plastic fake woodlap roof lining is covered in droplets. Obviously condensation due to cold weather (-12C Thursday at 630am) and us using more heating. Last winter we put an extra 200mm of rock wool on top of 1/3rd of the floorspace at one end up there. We moved in with the same at the opposite end so 2/3rds have extra 200mm or 400mm over half of this covered ends. Last year we didn't get this issue.
We have more junk up there but it's not right into the eaves. I don't think this is the issue but we're planning on a cull of stuff.
Is it likely to be the much colder weather conditions because nothing changed from last winter which didn't have an issue?
Solution? Do we need to do anything if it's an issue of this rare cold temperatures? Do we need more ventilation up there?
It's a 70s house with upgraded insulation and a new roof put in when the solar panels were put up in 2016. The roof lining I thought was insulated but seems not. Being a new roof I assume it's going to be built with adequate ventilation. There's plastic fascia with what I believe are eaves vents, need to check fire ridge vents. If not enough should I get more put in? I'll check tomorrow in case there's blocked eaves. Perhaps the insulation is affecting insulation.
What's the cheapest, what is the best or what is the easiest solution?
