This is exactly the same problem we just had and we replaced the bearings and it seemed ok for one short ride. However, it started again during a 75 mile ride. We had to replace the freehub body. Instead of a normal cartridge bearing on the inner side there is a plastic bushing which cannot be obtained to replace it - over time this wears away and allows the freehub to rock which causes the outer bearing to start to wear & then you get the clanking, grating, screeching. It happens on these wheels. A new freehub body is about £45 and is easy enough to fit. There is a company in USA which makes a freehub body to fit which has a bearing instead of this plastic bushing.
